    Hi Guest,
    Yours,
    Chandoo
  2. Hi All
Speed Things up
Discussion in 'VBA Macros' started by Stephen Spittal, Jan 18, 2017.
  1. Stephen Spittal
    Stephen Spittal New Member
    12
    Good Morning form the UK.
    I have a spreadsheet that is a download of a Database and I require to manipulate this to feed into a dashboard data table. I use the code below to do the manipulation but it takes forever and I do not know if or how to make it faster. can anyone help?
    Code (vb):
    Sub DashboardCSV()
    Windows("dashboard_v.csv").Activate
    Sheets("dashboard_v").Select
    Dim lr As Long, i As Long
    Dim FM As Integer
    Dim MM As Integer
    Dim AM As Integer
    Dim NM As Integer
    FM = 2
    MM = 4
    AM = 6
    NM = 12
    lr = Range("O" & Rows.Count).End(xlUp).Row
    For i = lr To 1 Step -1
    If Range("O" & i).Value = "-" And Range("O" & i).Offset(0, -9).Value = "MM" And Range("O" & i).Offset(0, -5).Value = "Impact Assessment" And Range("O" & i).Offset(0, -4).Value = "PENDING" Then
    For y = 1 To MM
    Range("O" & i).EntireRow.Copy
    Range("O" & i).EntireRow.Insert shift:=xlShiftDown
      Range("O" & i).Value = "03DZ - BZB"
      Range("o" & i).Offset(0, 2).Value = "0"
      Range("o" & i).Offset(0, 6).Value = "0"
      Range("O" & i).Offset(1).Value = "04DZ - BZB"
      Range("O" & i).Offset(1, 2).Value = "0"
      Range("O" & i).Offset(1, 6).Value = "0"
      Range("O" & i).Offset(2).Value = "09DZ - BZE"
      Range("O" & i).Offset(2, 2).Value = "0"
      Range("O" & i).Offset(2, 6).Value = "0"
      Range("O" & i).Offset(3).Value = "12DZ - BZH"
      Range("O" & i).Offset(3, 2).Value = "0"
      Range("O" & i).Offset(3, 6).Value = "0"
      Range("O" & i).Offset(4).Value = "***"
    If Range("O" & i).Value = "-" And Range("O" & i).Offset(0, -9).Value = "AM" And Range("O" & i).Offset(0, -5).Value = "Impact Assessment" And Range("O" & i).Offset(0, -4).Value = "PENDING" Then
    For y = 1 To AM
    Range("O" & i).Value = "05DZ - BZC"
    Range("O" & i).Offset(0, 2).Value = "0"
    Range("O" & i).Offset(0, 6).Value = "0"
    Range("O" & i).Offset(1).Value = "06DZ - BZC"
    Range("O" & i).Offset(2).Value = "07DZ - BZD"
    Range("O" & i).Offset(3).Value = "08DZ - BZD"
    Range("O" & i).Offset(4).Value = "10DZ - BZF"
    Range("O" & i).Offset(4, 2).Value = "0"
    Range("O" & i).Offset(4, 6).Value = "0"
    Range("O" & i).Offset(5).Value = "11DZ - BZG"
    Range("O" & i).Offset(5, 2).Value = "0"
    Range("O" & i).Offset(5, 6).Value = "0"
    Range("O" & i).Offset(6).Value = "***"
    If Range("O" & i).Value = "-" And Range("O" & i).Offset(0, -9).Value = "FM" And Range("O" & i).Offset(0, -5).Value = "Impact Assessment" And Range("O" & i).Offset(0, -4).Value = "PENDING" Then
    For y = 1 To FM
    Range("O" & i).Value = "01DZ - BZA"
    Range("O" & i).Offset(1).Value = "02DZ - BZA"
    Range("O" & i).Offset(2).Value = "***"
    If Range("O" & i).Value = "-" And Range("O" & i).Offset(0, -9).Value = "NM" And Range("O" & i).Offset(0, -5).Value = "Impact Assessment" And Range("O" & i).Offset(0, -4).Value = "PENDING" Then
    For y = 1 To NM
    Range("O" & i).Offset(2).Value = "03DZ - BZB"
    Range("O" & i).Offset(3).Value = "04DZ - BZB"
    Range("O" & i).Offset(4).Value = "05DZ - BZC"
    Range("O" & i).Offset(5).Value = "06DZ - BZC"
    Range("O" & i).Offset(6).Value = "07DZ - BZD"
    Range("O" & i).Offset(6, 2).Value = "0"
    Range("O" & i).Offset(6, 6).Value = "0"
    Range("O" & i).Offset(7).Value = "08DZ - BZD"
    Range("O" & i).Offset(7, 2).Value = "0"
    Range("O" & i).Offset(7, 6).Value = "0"
    Range("O" & i).Offset(8).Value = "09DZ - BZE"
    Range("O" & i).Offset(8, 2).Value = "0"
    Range("O" & i).Offset(8, 6).Value = "0"
    Range("O" & i).Offset(9).Value = "10DZ - BZF"
    Range("O" & i).Offset(9, 2).Value = "0"
    Range("O" & i).Offset(9, 6).Value = "0"
    Range("O" & i).Offset(10).Value = "11DZ - BZG"
    Range("O" & i).Offset(10, 2).Value = "0"
    Range("O" & i).Offset(10, 6).Value = "0"
    Range("O" & i).Offset(11).Value = "12DZ - BZH"
    Range("O" & i).Offset(11, 2).Value = "0"
    Range("O" & i).Offset(11, 6).Value = "0"
    Range("O" & i).Offset(12).Value = "***"
    Windows("Stage 2 Interactive Change Management Dashboard.xlsm").Activate
    ActiveWindow.WindowState = xlMaximized
    MsgBox ("dashboard_v.csv Updated")
  2. PCosta87
    PCosta87 Well-Known Member
    870
    Hi Stephen,
    The speed at which a code runs is always dependent on the processing power of the machine it is running on.
    That being said, there's a number of "tricks" you can use to speed up the execution of subroutines in VBA... some are simple lines of code (to disable Screen or Status Bar Updates, for instance) and others are related to the actual code and the way it was written (optimization).
    Please take a look at the following:
    http://datapigtechnologies.com/blog/index.php/ten-things-you-can-do-to-speed-up-your-excel-vba-code/
    Note that not all can/should be used in all situations.
    Now, for the specific code provided, please upload a sample file if you can and I will gladly take a look at it.
    Hope this helps
  3. Monty
    Monty Well-Known Member
    721
    Hello Stephen
    Check the speed now..Hope this helps.
    Code (vb):
    Sub DashboardCSV()
    Dim FM As Integer
    Dim MM As Integer
    Dim AM As Integer
    Dim NM As Integer
    FM = 2
    MM = 4
    AM = 6
    NM = 12
    For y = 1 To MM
    For y = 1 To AM
    For y = 1 To FM
    For y = 1 To NM
    jamesexcel1970 and Arpanakumar like this.
  4. p45cal
    p45cal Well-Known Member
    694
    try:
    Code (vb):
    Sub DashboardCSV()
    'On Error GoTo exitNicely 'reinstate this line after testing.
    Dim FM As Long, MM As Long, AM As Long, NM As Long
    FM = 2
    MM = 4
    AM = 6
    NM = 12
      With Range("O" & i)
      If .Value = "-" And .Offset(0, -5).Value = "Impact Assessment" And .Offset(0, -4).Value = "PENDING" Then
      Select Case .Offset(0, -9).Value
      Case "MM"
      Rows(i).Offset(1).Resize(MM).Insert
      Rows(i).Copy Rows(i).Offset(1).Resize(MM)
      .Offset(, 2).Resize(4).Value = "0"
      .Offset(, 6).Resize(4).Value = "0"
      .Resize(5).Value = Application.Transpose(Array("03DZ - BZB", "04DZ - BZB", "09DZ - BZE", "12DZ - BZH", "***"))
      Case "AM"
      Rows(i).Offset(1).Resize(AM).Insert
      Rows(i).Copy Rows(i).Offset(1).Resize(AM)
      .Offset(, 2).Resize(6).Value = "0"
      .Offset(, 6).Resize(6).Value = "0"
      .Resize(7).Value = Application.Transpose(Array("05DZ - BZC", "06DZ - BZC", "07DZ - BZD", "08DZ - BZD", "10DZ - BZF", "11DZ - BZG", "***"))
      Case "FM"
      Rows(i).Offset(1).Resize(FM).Insert
      Rows(i).Copy Rows(i).Offset(1).Resize(FM)
      .Offset(, 2).Resize(2).Value = "0"
      .Offset(, 6).Resize(2).Value = "0"
      .Resize(3).Value = Application.Transpose(Array("01DZ - BZA", "02DZ - BZA", "***"))
      Case "NM"
      Rows(i).Offset(1).Resize(NM).Insert
      Rows(i).Copy Rows(i).Offset(1).Resize(NM)
      .Offset(, 2).Resize(12).Value = "0"
      .Offset(, 6).Resize(12).Value = "0"
      .Resize(13).Value = Application.Transpose(Array("01DZ - BZA", "02DZ - BZA", "03DZ - BZB", "04DZ - BZB", "05DZ - BZC", "06DZ - BZC", "07DZ - BZD", "08DZ - BZD", "09DZ - BZE", "10DZ - BZF", "11DZ - BZG", "12DZ - BZH", "***"))
      End Select
      End With  'Range("O" & i)
    exitNicely:
  5. p45cal
    694
    …or shorter code (and perhaps easier to tweak) but I doubt any faster:
    Code (vb):
    Sub DashboardCSV2()
    Dim FM As Long, MM As Long, AM As Long, NM As Long, ZZ As Long
    FM = 2
    MM = 4
    AM = 6
    NM = 12
    Dim myArray(2 To 12)
    myArray(FM) = Application.Transpose(Array("01DZ - BZA", "02DZ - BZA", "***"))
    myArray(MM) = Application.Transpose(Array("03DZ - BZB", "04DZ - BZB", "09DZ - BZE", "12DZ - BZH", "***"))
    myArray(AM) = Application.Transpose(Array("05DZ - BZC", "06DZ - BZC", "07DZ - BZD", "08DZ - BZD", "10DZ - BZF", "11DZ - BZG", "***"))
    myArray(NM) = Application.Transpose(Array("01DZ - BZA", "02DZ - BZA", "03DZ - BZB", "04DZ - BZB", "05DZ - BZC", "06DZ - BZC", "07DZ - BZD", "08DZ - BZD", "09DZ - BZE", "10DZ - BZF", "11DZ - BZG", "12DZ - BZH", "***"))
      With Range("O" & i)
      ZZ = 0
      Case "MM": ZZ = MM
      Case "AM": ZZ = AM
      Case "FM": ZZ = FM
      Case "NM": ZZ = NM
      End Select
      If ZZ > 0 Then
      Rows(i).Offset(1).Resize(ZZ).Insert
      Rows(i).Copy Rows(i).Offset(1).Resize(ZZ)
      .Offset(, 2).Resize(ZZ).Value = "0"
      .Offset(, 6).Resize(ZZ).Value = "0"
      .Resize(ZZ + 1).Value = myArray(ZZ)
    exitNicely:
  6. Monty
    721
    Hi Stephen,
    Please acknowledge if it has improved the speed of the macro.
  7. p45cal
    694
    Monty,
    Stephen has probably got the speed he needs - it cost him nothing - so why should he bother acknowledging?
    …until he wants more help, whereupon he'll discover his past helpers' willingness to do so has dried up.
  8. Monty
    721
    Hello P45cal
    We expect when some solution is given and it is working or not ...or further any help required.
    we are here to provide answerfor the question...at the same time..we also requiredd help for our questions...
    if somebody responds if it is working then it will also help somebody in forum.
    Thats the Intension.
  9. p45cal
    694
    I'm 100% with you!
  10. Arpanakumar
    Arpanakumar Member
    88
    Hello Monty.
    I totally agree with you...
  11. Stephen Spittal
    12
    I would like to thank you all sorry for the late reply I have been in hospital without access to the internet. I have not had a chance to check all the replys but thank you very much.
    Arpanakumar likes this.
  12. Stephen Spittal
    12
    I have tried to up load all the files but it says it is too big I will try another way thank you all once again
  13. Monty
    721
  14. Stephen Spittal
    12
    Good Morning All,
    I have tried all the variations of the code and the code works when I use a small set of data my problem is that when I use the full data set I get a not responding.
    I ask in hope that someone is willing to help.
  15. Marc L
    Marc L Excel Ninja
    3,027
    Hi !
    « Not responding » often means a procedure is running,
    just wait until its ending …
    Adding DoEvents statement just before Next codeline
    can help to disapear this non responding state
    even if execution may be longer …
  16. Stephen Spittal
    12
    Thank you will give it a try
  17. p45cal
    694
    We'd need a file to experiment on.
  18. Arpanakumar
    Arpanakumar Member
    88
    Hello Mark.
    Adding DoEvents statement just before Next codeline.
    Can we use where ever we use loops same case when we have more number of line and loop running it goes not responding mode but still works, how can we make our window active..Please advise.
  19. Marc L
    Marc L Excel Ninja
    3,027
    As VBA is no multi-tasks, so Excel neither,
    when a procedure lasts, you just have to wait until its ending …
    DoEvents statement is useful for those who are scary to see
    a non response status as a procedure is still running
    but can increase execution time, see VBA inner help …
    Useful too to manually break a never ending loop in case of a bad design !
    Time can be reduced by desactivating during execution properties
    ScreenUpdating and Calculation, to see in VBA inner help …
  20. Stephen Spittal
    12
    Im having difficulty uploading a file
  21. Stephen Spittal
    12
    This is my full code, I have attached the file that concerns Sub DashboardCSV as the rest contain restricted data,
    Code (vb):
    Function WEEKNR(Datum As Date) As Integer
    Dim lnDatum As Long
      lnDatum = DateSerial(Year(Datum - Weekday(Datum - 1) + 4), 1, 3)
      WEEKNR = Int((Datum - lnDatum + Weekday(lnDatum) + 5) / 7)
    End Function
    Sub OpenLNKS()
    Workbooks.Open Filename:= _
      "H:\Desktop\Type 26 Detail Design Change Managment\dashboard_v.csv"
      "H:\Desktop\Type 26 Detail Design Change Managment\change report.xls"
      "H:\Desktop\Type 26 Detail Design Change Managment\impact_assessment_cr's_by_team.csv"
    Sub UpdateCHANGERPT()
    Application.DisplayStatusBar = False
    Workbooks("change report.xls").Sheets("default").Activate
    Range("A:A").Select
    With Selection
    Selection.NumberFormat = "General"
    .Value = .Value
    Workbooks("change report.xls").Save
    Sub UPDATEIABYTEAM()
    Workbooks("impact_assessment_cr's_by_team.csv").Sheets("impact_assessment_cr's_by_team").Activate
    Rows("1:1").Select
      Selection.Insert Shift:=xlDown, CopyOrigin:=xlFormatFromLeftOrAbove
      Range("I1").Select
      Sheets("Design Zones").Select
      Range("B2:B13").Select
      Selection.Copy
      Windows("impact_assessment_cr's_by_team.csv").Activate
      Selection.PasteSpecial Paste:=xlPasteAll, Operation:=xlNone, SkipBlanks:= _
      False, Transpose:=True
      Range("I2").Select
      ActiveCell.FormulaR1C1 = "2"
      Range("J2").Select
      ActiveCell.FormulaR1C1 = "3"
      Range("K2").Select
      ActiveCell.FormulaR1C1 = "4"
      Range("L2").Select
      ActiveCell.FormulaR1C1 = "5"
      Range("M2").Select
      ActiveCell.FormulaR1C1 = "6"
      Range("N2").Select
      ActiveCell.FormulaR1C1 = "7"
      Range("O2").Select
      ActiveCell.FormulaR1C1 = "8"
      Range("P2").Select
      ActiveCell.FormulaR1C1 = "9"
      Range("Q2").Select
      ActiveCell.FormulaR1C1 = "10"
      Range("R2").Select
      ActiveCell.FormulaR1C1 = "11"
      Range("S2").Select
      ActiveCell.FormulaR1C1 = "12"
      Range("T2").Select
      ActiveCell.FormulaR1C1 = "13"
      Columns("I:I").Select
      Selection.Insert Shift:=xlToRight, CopyOrigin:=xlFormatFromLeftOrAbove
      Range("I3").FormulaR1C1 = "=CONCATENATE(RC[-8],RC[-3])"
      Dim lRowCountb As Long
      lRowCountb = Workbooks("impact_assessment_cr's_by_team.csv").Sheets("impact_assessment_cr's_by_team").UsedRange.Rows.Count
      p = lRowCountb
      With Workbooks("impact_assessment_cr's_by_team.csv").Sheets("impact_assessment_cr's_by_team").Range("I3")
      .AutoFill .Resize(p + 1, 1), xlFillCopy
      Workbooks("impact_assessment_cr's_by_team.csv").Save
    Sub DashboardCSV()
    workbooks("dashboard_v.csv").Sheets("dashboard_v").activate
    Columns("F:F").Select
      Selection.Replace What:="-", Replacement:="NM", LookAt:=xlPart, _
      SearchOrder:=xlByRows, MatchCase:=False, SearchFormat:=False, _
      ReplaceFormat:=False
    FM = 2
    MM = 4
    AM = 6
    NM = 12
      With Range("O" & i)
      Case "MM"
      .Offset(, 2).Resize(4).Value = ""
      .Offset(, 6).Resize(4).Value = ""
      .Resize(5).Value = Application.Transpose(Array("3DZ - BZB", "4DZ - BZB", "9DZ - BZE", "12DZ - BZH", "***"))
      Case "AM"
      .Offset(, 2).Resize(6).Value = ""
      .Offset(, 6).Resize(6).Value = ""
      .Resize(7).Value = Application.Transpose(Array("5DZ - BZC", "6DZ - BZC", "7DZ - BZD", "8DZ - BZD", "1DZ - BZF", "11DZ - BZG", "***"))
      Case "FM"
      .Offset(, 2).Resize(2).Value = ""
      .Offset(, 6).Resize(2).Value = ""
      .Resize(3).Value = Application.Transpose(Array("1DZ - BZA", "2DZ - BZA", "***"))
      Case "NM"
      .Offset(, 2).Resize(12).Value = ""
      .Offset(, 6).Resize(12).Value = ""
      End Select
    ActiveSheet.UsedRange.Replace "-", "", LookAt:=xlWhole
    Workbooks("dashboard_v.csv").Save
    Dim dtDate As String
    dtDate = Format(CStr(Now), "DD MM YYYY HH MM")
    Dim Fname As String
    Dim Fpath As String
    Dim Fnew As String
    Fname = "dashboard_v" & dtDate & ".CSV"
    Fpath = "H:\Desktop\dashboard_v history\"
    Fnew = Fpath & Fname
    Workbooks("dashboard_v.csv").SaveCopyAs Filename:=Fnew
    MsgBox (Fnew)
    exitNicely:
    Sub ChangeManagement()
    Workbooks("Stage 2 Interactive Change Management Dashboard.xlsm").Sheets("Dashboard Table").Activate
      Range("X2").FormulaR1C1 = _
      "=IF(COUNTIFS([@[K2_STATE]],""Sent for Impact Assessment"",[@[Assess Status]],""PENDING"")=1,VLOOKUP([@[IA LOOKUP]],'impact_assessment_cr''s_by_team.csv'!C9:C21,HLOOKUP([@BUILDZONE],'impact_assessment_cr''s_by_team.csv'!R1C10:R2C21,2,FALSE),FALSE),dashboard_v.csv!RC[-7])"
      If Sheets("Dashboard Table").FilterMode Then
      Sheets("Dashboard Table").ShowAllData
      Dim i As Long
      Dim lRowCount As Long
       lRowCount = Workbooks("dashboard_v.csv").Sheets("dashboard_v").UsedRange.Rows.Count
      i = lRowCount - 2
      With Sheets("Dashboard Table").ListObjects("Table2")
      .Resize Range("$A$1:$BF$" & i)
    Sub SaveAllOpenFiles()
    ' saves all open Excel files
    ' excludes
    '  read only +
    '  previously unsaved files
    Dim wb As Workbook
    'go through all open workbooks
    For Each wb In Workbooks
    wb.RefreshAll
      'only save those that
      'aren't read only +
      'those not previously saved (new workbooks)
      '.Path is the folder path of the file
      If Not wb.ReadOnly And Len(wb.Path) <> 0 Then
      wb.Save
    Next wb
    'clears the object variable from memory
    Set wb = Nothing
    Call OpenLNKS
    Call UpdateCHANGERPT
    Call UPDATEIABYTEAM
    Call DashboardCSV
    Call ChangeManagement
    Call SaveAllOpenFiles
  22. p45cal
    694
    Running DashboardCSV here took 17 secs (I only needed to change FPath, otherwise as-is).
    Some 2.2k rows are added.
    It's an 8+yr. old computer.
    Try putting a STOP instruction, (or a breakpoint) before any files are saved in case it's that which is taking the time.
    Also you can put a
    Debug.Assert i > 13200
    line just after:
    and when you run it will stop at that line when i gets down to 13200, then to move on, press F8 on the keyboard once or twice to move off the Debug line, then adjsut the debug line to a smaller value, say 12500, then press F5 on the keyboard to continue running, etc. etc. which should give you a better idea of what might be slow.
    (BTW, there's only one row (row 6309) that inserts new rows above row 10200 on your original csv file.)
    This could be done in-memory with arrays, but it would take significant time for me to develop it correctly and tested, and running it that way would take only a fraction of a second or maybe 1 second to update the sheet.
    Are you testing the speed of DashboardCSV independently of the other called macros?
  23. Stephen Spittal
    12
    Thanks for having a look yeah running independently but trying to get it to run from the main file so that only 1 command button basically the main file has =dashboard.csva2 and so on
  24. Stephen Spittal
    12
    I will try and provide the other sheets when at work tomorrow or at least a cut down version. My main when I look at the task manager and running processes I'm see circa 403000 kb memory used when it freezes
  25. p45cal
    694
    So is it freezing only when you try to run them all together (or is DashboardCSV freezing the computer by itself)?
Share This Page
