Carlos Ruano
Hi, I am completely new to VBA, and am just getting to the point where I am fairly confident with using Excel. I probably have more Excel knowledge than your average Joe, but nowhere near the knowledge of you fine folks
Can you tell me if it is even possible to do what I want? Here is what I have and what I want to do (example file attached):
I have found some awesome macros that split data into multiple worksheets based on criteria in columns, but none that fit my requirements for matching test name to sheet name, and allowing 3 blank rows at the top for sheets 2 through 34. Is this even possible? By the way, I am using Excel 2010. Thank you for your time, and any thoughts or feedback would be very much appreciated!
Thank you,
Carlos
- I created a template with 35 sheets. Each sheet has a table with only two rows (header row and empty row waiting for data to be pasted).
- 1st sheet is named "NOH402 - All Results-SI". A1 : P1 contains the column headers
- A2 : P2 are empty cells, but are part of the table ready to accept the source data. Actual column headers are as follows:
- All other sheets are named according to "Test Name" (Column K). There are 55 tests, but I am only interested in 34 of them.
- For these sheets, the column headers (exactly the same as above) are contained in A4 : P4 (I want the 3 blank rows above the header row).
- Additional information: tables in sheets 2 through 34 have additional columns. These consist of one spacer column which will not contain data, and then additional columns with formulas. As it is now, I paste my source data into the first sheet. Then, I sort and paste all rows of one test name into the corresponding sheet and repeat until all sheets have been populated with the source data. The tables expand accordingly per the number of rows that I paste, and the formulas in the right columns do what I need them to do.
Thank you,
Carlos
