thank you, but its giving only subtotal for B, I Need subtotal for A and B COLUMN as shown in the output sheet.Hey Prasad.
Try this!
Sub Subtotal()
Range("a4").Select
Range(Selection, Selection.End(xlToRight)).Select
ActiveWindow.SmallScroll Down:=3
Selection.Subtotal GroupBy:=1, Function:=xlSum, TotalList:=Array(6, 7, 8, _
9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19), Replace:=False, PageBreaks:=False, _
SummaryBelowData:=True
Range("B4").Select
Range(Selection, ActiveCell.SpecialCells(xlLastCell)).Select
Range("B4:T692").Select
Range("a4").Select
ActiveSheet.Outline.ShowLevels RowLevels:=3
Range("E1").CurrentRegion.SpecialCells(xlCellTypeVisible).Font.Bold = True
ActiveSheet.Outline.ShowLevels RowLevels:=4
Thank you so much its working greatThis is fairly standard pivot table stuff.
In the attached, next to your expected output table is a pivot table.
Currently it shows only Vendors 1 and 2 to match your expected output. It only takes an adjustment of the filter in cell K1 to include others (or all) the vendors.
You'll also note that the percentages are correct.
Regarding making totals and subtotals bold then maybe something like:
but since your code obviously works on a different range from your sample sheet I don't know exactly which columns they're in.Code:ActiveSheet.Outline.ShowLevels RowLevels:=3 Range("E1").CurrentRegion.SpecialCells(xlCellTypeVisible).Font.Bold = True ActiveSheet.Outline.ShowLevels RowLevels:=4
This is not necessary in a pivot table.
