Sum Product & Data Filter
Similar to CountIF & SumIF, how good it will be if we have SumProductIF!!!!
Likewise, in data filter it would be of great help if we have an inverse selection option. For ex: if we have selected 3 out of 10 values in the filter and now we need to select the rest 7 values, its manual and time consuming.
Many a times, I feel handicapped that we don't have functions like this.
Please suggest if you have any alternatives.
Thanks a lot.
Although there is no SUMPRODUCTIF( but we can implement same, and sometime even better logics (i.e. mixed, 2D arrays) with SUMPRODUCT.
for example following SUMIF and SUMPRODUCT produces same output:
=SUMIF(A1:A10,B1,C1:C10)
=SUMPRODUCT((A1:A10=B1)*(C1:C10))
Have you tried this?
Thank you Khalid.
I have a different issue and I hope the attachment will make it clear. Please help.
  • Sum Product & Data Filter.xlsx
No problem SUMPRODUCT is more powerful:
=SUMPRODUCT(($B$3:$B$28=$C30)*(D$3:D$28)*($C$3:$C$28)/SUMPRODUCT(($B$3:$B$28=$C30)*($C$3:$C$28)))
Enter in D30, copy down and across
Keep visiting keep learning, that's we do here all the day.
For Filter, use Advance Filter.
First make a copy of your column b, at any other column, say column C, and enter values which you want to include in your filter.
Than select your range: B2:B28
Go to Data > Advance
List Range = $B$2:$B$28
Criteria Range = $C$2:$C$24
Hit OK.
See the attached.
