Sum with 2 criteria in column and row
I have problem to sum base on 2 criteria. One criteria range in row and other criteria range in column. Do you have any way to solve it?
Thanks,
  • Sum 2 criterail in col and row.xlsx
Another non-array formula possible………..
In B18, copy across and down :
=SUMPRODUCT(($A$4:$A$12=$A18)*($C$2:$G$2=B$17),$C$4:$G$12)
Bosco
Thanks for the formula. I have one more criteria and not sure if you can help or not.
My problem is I want to sum all record in the most left column each week base on region.
Please view attached file for more detail.
Thanks,
Thanks,
In B18, formula copy across and down :
=SUMIF($A$4:$A$12,$A18,INDEX($C$4:$G$12,0,INDEX(MATCH(2,1/($C$2:$G$2=B$17)),0)))
  • 2 criterail in col and row.xlsx
