Dear All,
The attached file shows a picking list which we use to place purchase order. There are 2 sheets, Picking List and Code & Description List, where Picking list is actual list of purchase order and Code & Description List contributes as a source for lookup and drop down menu.
Now, I am looking for help on 2 main issues:
1. Image below shows dark green cells with sumproduct functions, which calculates quantity of item (clips) depending on post (another item) length and quantities.
Now if you go to Codes & Description sheet, there are 6 codes:
P50253H100
P50503H100
P50253H100V
P50503H100V
P50253H75
P50503H75
Question: Is it possible to count P50253H100 and P50503H100 as one item and incorporate their lengths and quantities in existing if(sumproduct) function?
2. In the same image, you will see #N/A which is due to lookup error.
Question: Is it possible to get rid of those #N/As, if all dark green cells are empty? I tried using ISBLANK, but it seems to be not working.
Thanks for taking time to answer my questions.
Nirav
P50253H100
P50503H100
P50253H100V
P50503H100V
P50253H75
P50503H75
Nirav
