Transpose and create dates
DaveJenkins
Hi All,
I need some advice / pointing in the right direction.
In the file that I have attached, I have shown the data I receive, unfortunately they wont/cant change the format they have it in. However, I require the data tranposing and then dates for that week filling in based on the week commencing date at the top. I have shown this in the file.
I think what I want is possible, however, I dont know whether it would be done in VBA or some advanced formula.
I thought that I could do something with a pivot table but it appears that the pivot hates the original format!
Any advice, tips or code would be very appreciated.
Dave
  • Sample Data.xlsx
Wow! Just wow!
I'm going to spend some time breaking apart those formula's so I can understand how they work for future reference.
A massive THANK YOU!!
--EDIT -- Got it, broke apart the formulas and understand whats happening. It makes sense now. I dont think I could write something like that off the top of my head though! But thats why you're a Ninja ;)
Hi Somendra,
I have tried to incorporate it into the following sheet and for some reason it doesn't work.
I've tinkered a little to rename the 'Names' and moved formulas onto a new sheet so I dont mix the old and new data. I've triple checked the formulas and they all look good.
I've got the requirement to do it 97-2003 so ssis can pick it up. I dont think thats the issue as I tried it in 2010 as well and get the same issues.
The issue appears to be it just returning a number rather than a date.
Dave.
  • KanaForecastImport.xls
