Sub small_index()
Dim var1 As Integer
Dim var2 As Integer
For i = 2 To 7
For j = 2 To 4
var1 = Application.WorksheetFunction.Match(Cells(i, 1).Value, Sheet1.Range("A3:A8"), 0)
var2 = Application.WorksheetFunction.Match(Cells(1, j).Value, Sheet1.Range("B2:F2"), 0)
Cells(i, j) = Application.WorksheetFunction.Index(Sheet1.Range("B3:F8"), var1, var2)
Next j
This should work:
Code:Sub small_index() Dim var1 As Integer Dim var2 As Integer Application.ScreenUpdating = False On Error Resume Next For i = 2 To 7 For j = 2 To 4 var1 = Application.WorksheetFunction.Match(Cells(i, 1).Value, Sheet1.Range("A3:A8"), 0) var2 = Application.WorksheetFunction.Match(Cells(1, j).Value, Sheet1.Range("B2:F2"), 0) Cells(i, j) = Application.WorksheetFunction.Index(Sheet1.Range("B3:F8"), var1, var2) Next j Next i Application.ScreenUpdating = True End Sub
Untested though
I recommend avoiding the "On error resume next" as much as you can... that was why it didn't throw an error when you ran the code and, most likely, why you couldn't find the problem...
Hope it helps
Perhaps something like this:Hello Costa,
Thank you for the help. It worked partially. I have some cells for which there is no data, I want to put them blank. how do I do that?
Thank you
Sub small_index()
Dim var1 As Integer
Dim var2 As Integer
For i = 2 To 7
For j = 2 To 4
If Err = 0 Then
Err.Clear
Next j
Don't mention itThanks a lot PCosta, its working
