Userform make it copy and paste in two Rows
kalua1231
Hy guys, i am trying to find a way to make this userform to write giving information in two rows
Row One Having
ws.Cells(iRow, 3).Value = Me.textbox_name.Value
ws.Cells(iRow, 4).Value = Me.textbox_name.Value
ws.Cells(iRow, 5).Value = Range("C2").Value
and
Row Two having
Original code is underneath this line, if you will need any additional information please feel free to ask. Thanks again Chandoo,
'find first empty row in database
iRow = ws.Cells(Rows.Count, 1).End(xlUp).Offset(1, 0).Row
'check for a Name number
If Trim(Me.textbox_name.Value) = "" Then
Me.textbox_name.SetFocus
MsgBox "Please complete the form"
Exit Sub
'copy the data to the database
When i click on the Add Task it duplicated the information in two rows the only information that will not be duplicated in the second row will be the information that is in the (C) column,
Hope this is more clearer.
Normally when you use a userform it only input information on one row, i am trying to get it to work, so that it may input the information on two rows.
Second row will have the same information as the first only difference will be leaving out the information that is on the (C) column for the second row.
  • Fix 8 24.xlsm
Other pictures attached, trying to make it easier for everyone to understand. hope this works
Try the following .. I just added two lines of code
Private Sub Cmdbutton_close_Click()
    Unload Me
    Dim iRow As Long
    Dim ws As Worksheet
    Set ws = Worksheets("GENERAL")
        Exit Sub
    ws.Cells(iRow + 1, 4).Value = Me.textbox_name.Value
    ws.Cells(iRow + 1, 5).Value = Range("C2").Value
    MsgBox "Data added", vbOKOnly + vbInformation, "Data Added"
    'clear the data
    Me.textbox_name.Value = ""
As for the added lines are
