Vishal.jagani
Hello All,
Good Morning
I want to make macro using One CSV file data
main Question : How can copy data from CSV file and paste into excel file and after I could modify that data
Open CSV file should be automatically (When I run Macro at that time It should ask with popUp window for CSV file, and I can select file and all file data should be open Excel file)
After I should be able to modify that data, adding new columns, deleting columns
all operation should be done with Macro
All things Could be possible with Recording ?
My main question is that : How can record macro for data modification - after copied data from csv file
Is it possible that half code is written by manually and half operation done by Recording ?
and after that I can use that coding only One file with macro
I am so confuse about this thing from last week
Thnks
Vishal
Good Morning
Thnks
Vishal
