Using Date Range in For Each Loop
How would I set this code up to return all data in the range between two dates?
Right now it returns all the dates.
For Each i In SourceRange
  If i.Value >= StartDate <= EndDate Then
  'Set the cell in column A to be the file name.
  DestRange.Cells(NRow, 1).Value = WorkBk.Worksheets(1).Cells(2, 1).Value
  DestRange.Cells(NRow, 2).Value = SourceRange.Cells(i.Row - 24 + 1, 1).Value
  DestRange.Cells(NRow, 3).Value = SourceRange.Cells(i.Row - 24 + 1, 7).Value
  DestRange.Cells(NRow, 4).Value = SourceRange.Cells(i.Row - 24 + 1, 9).Value
  NRow = NRow + 1
You've now shown how your variables are defined or where they're coming from, but I might suggest doing something like:
Dim NRow As Long
Dim i As Range
Dim myVal As Date
Dim StartDate As Date
Dim EndDate As Date
    'Verify that cell value gets treated as a date
    myVal = CDate(i.Value)
    If myVal >= StartDate <= EndDate Then
        NRow = NRow + 1
OK Luke,
I set it up and it still pulls in all the dates. I had my variables setup exactly as you.
Sub MergeAllWorkbooks()
  Dim SummarySheet As Worksheet
  Dim FolderPath As String
  Dim NRow As Long, LastRow As Long
  Dim FileName As String
  Dim WorkBk As Workbook
  Dim DestRange As Range, FindRange As Range, i As Range, SourceRange As Range
  Dim StartDate As Date, EndDate As Date, myVal As Date
  'Enter a start date and an end date.
  StartDate = Application.InputBox("Please enter a start date as MM/DD/YYYY.", "Macro Canceled")
  If StartDate = False Then
  MsgBox "Macro was cancelled.", 64, "Cancel was clicked."
  Exit Sub
  EndDate = Application.InputBox("Please enter a end date as MM/DD/YYYY.", "Macro Canceled")
  If EndDate = False Then
  Exit Sub
  ' Create a new workbook and set a variable to the first sheet.
  Set SummarySheet = Workbooks.Add(xlWBATWorksheet).Worksheets(1)
  ' This is the folder path to point to the files you want to use.
  FolderPath = "C:\Test\Test Files\"
  ' NRow keeps track of where to insert new rows in the destination workbook.
  NRow = 1
  ' Call Dir the first time, pointing it to all Excel files in the folder path.
  FileName = Dir(FolderPath & "*.xl*")
  ' Loop until Dir returns an empty string.
  Do While FileName <> ""
  ' Open a workbook in the folder
  Set WorkBk = Workbooks.Open(FolderPath & FileName)
  LastRow = WorkBk.Worksheets(1).Range("A24").End(xlDown).Row
  ' Set the source range to be A24 through I and LastRow.
  Set SourceRange = WorkBk.Worksheets(1).Range("A24:I" & LastRow)
  ' Set the destination range to start at column A.
  Set DestRange = SummarySheet.Range("A" & NRow)
  ' Copy the values from the source to the destination.
  NRow = NRow + 1
  'Place formatting here.
  ' Close the source workbook without saving changes.
  WorkBk.Close savechanges:=False
  ' Use Dir to get the next file name.
  FileName = Dir()
  LastRow = Empty
  Loop
  ' Call AutoFit on the destination sheet so that all
  ' data is readable.
  With SummarySheet
  Range("A1").Select
  Selection.EntireRow.Insert
  Range("A1") = "Bond Name"
  Range("B1") = "Date"
  Range("C1") = "Int. Income"
  Range("D1") = "Premium Amort."
  With SummarySheet
  .Sort.SortFields.Clear
  .Sort.SortFields.Add Key:=Range("A1:A10000"), SortOn:=xlSortOnValues, Order:=xlAscending, DataOption:=xlSortNormal
  With SummarySheet.Sort
  .SetRange Range("A1:D10000")
  .Header = xlYes
  .MatchCase = False
  .Orientation = xlTopToBottom
  .SortMethod = xlPinYin
  .Apply
  With SummarySheet
  .Columns("C:D").Select
  With Selection
  .NumberFormat = "#,##0.00_);[red](#,##0.00)"
  With SummarySheet
  Rows("1:1").Select
  With Selection
  .Font.Bold = True
  .HorizontalAlignment = xlCenter
  .VerticalAlignment = xlBottom
  .WrapText = False
  .Orientation = 0
  .AddIndent = False
  .IndentLevel = 0
  .ShrinkToFit = False
  .ReadingOrder = xlContext
  .MergeCells = False
  .Columns.AutoFit
  .Range("A1").Select
  With SummarySheet
  .Columns.AutoFit
  .Range("A1").Select
  Windows("Summary Macro Date Range.xlsm").Activate
  ActiveWindow.Close
Wow, I screwed that up big time...not sure how I copied that wrong. The If statement should be:
 If myVal >= StartDate And myVal <= EndDate Then
Again, apologies for my error there. :(
Man Luke what am I gonna to do with you? Just kidding.:)
The change worked perfect!
I had the code like this before asking for help so I was close!
If I >= StartDate And <= EndDate Then
But it was an error. I think at one time I eliminated the "And".
I'm learning this stuff. At least I was able to build most all the code myself. Those If Then loops still get me.:mad:
