using find and replace
dear all ,
I want to replace only 0 with 2 in the below formula.
=ROUND($E$247*J250,0)
How can i use find and replace to achieve this
the final outcome should be---
=ROUND($E$247*J250,2)
thanx and rgds
Make sure the Find and Replace Options are set to look at Formulas, not values. Then, replace:
,0)
with:
,2)
dear luke and narayan,
problem is that it also replaces 0 of J250 and becomes J252. Is there a way so that only 0 is replaced by 2
If you put correct input for in Find and Replace, it would work perfectly.
Note: ",0)" is changed to ",2)".
regards,
PrasadDN
