    Hi Guest,
    Yours,
    Chandoo
  2. Hi All
using to dictionary to select range to merge
Discussion in 'VBA Macros' started by monoj chakraborty, Jul 17, 2017 at 7:38 AM.
  1. monoj chakraborty
    monoj chakraborty New Member
    27
    I am using the following code :
    Code (vb):
    Sub countThings()
        Dim ws As Worksheet
        Dim countries As Object
        Set ws = Sheets("gsv")
        Set countries = CreateObject("Scripting.Dictionary")
            For x = 6 To 75
                If Not countries.exists(ws.Range("A" & x).Value) Then
                countries.Add ws.Range("A" & x).Value, 1
                countries(ws.Range("A" & x).Value) = countries(ws.Range("A" & x).Value) + 1
            Next x
    ' programme segment to select the rows to merge
    ' coding first to identify the first position of name of the country
    ' first step will be to identify items which have got value >1
         Dim scroll As Integer
            For scroll = 0 To countries.Count - 1
                Debug.Print countries.items()(scroll), _
                countries.keys()(scroll)
            Next scroll
    but I am not able to write the code which will do the following :
    1. Select items with value more than 1
    2. For those items, get the values for the keys
    3. For those keys, find the cell address
    4. merge the rows whereby the number of rows to merge is supplied by the corresponding item value
    the file and macro attached
    Mod Edit: Code tags added
  2. p45cal
    p45cal Well-Known Member
    716
    That sounds like a hard way to go about it, especially if there are similar names in different countries (same names in non-contiguous ranges in column A).
    To get you started , try:
    Code (vb):
    Sub blah()
    StartRw = 6
    EndRw = 75
    StartBlock = StartRw
    Do Until StartBlock > EndRw
      EndBlock = StartBlock
      Do Until Cells(StartBlock, 1) <> Cells(EndBlock + 1, 1) Or EndBlock >= EndRw
        EndBlock = EndBlock + 1
      Loop
      If EndBlock <> StartBlock Then
        Range(Cells(StartBlock, 1), Cells(EndBlock, 1)).Select
        MsgBox "Pause to show next rows to merge"
      StartBlock = EndBlock + 1
    Loop
  3. monoj chakraborty
    27
    thanks - this will work. I have used similar algo to solve this. the reason i posted this was to try the dictionary route as i have just started using this and find it very powerful. would have a trick to get here using the dictionary route
  4. Chihiro
    Chihiro Well-Known Member
    3,316
    As p45cal indicated. Scripting.Dictionary isn't the ideal method for this operation.
    Also, your explanation is bit unclear on what calculation should be performed on ranges to merge (simple addition?). And what values should be kept for Brand column etc.
    Just as FYI, here's some examples of using dictionary.
    1. To count occurrence of each value in Column A, excluding blanks. Note that it's faster to loop using Range object rather than row index.
    Code (vb):
    Sub Demo()
    Dim dic As Object, Key
    Dim cel as Range
    Set dic = CreateObject("Scripting.Dictionary")
    For Each cel In Range("A6:A75")
        If cel.Value <> "" Then _
        dic(cel.Value) = IIf(dic(cel.Value) = 0, 1, dic(cel.Value) + 1)
    For Each Key In dic.Keys
        If dic(Key) > 1 Then Debug.Print Key & " has "; dic(Key) & " items"
    2. To store range object that needs merging directly into dictionary.
    Code (vb):
    Sub Demo()
    Dim dic As Object, Key, rCount
    Dim cel As Range
            rCount = Evaluate("=SUMPRODUCT((--EXACT(" & Chr(34) & cel.Value & Chr(34) & ", GSV!$A$6:$A$75)))")
            If rCount > 1 Then
                If Not dic.Exists(cel.Value) Then _
                dic.Add Key:=cel.Value, Item:=Range(cel, cel.Offset(rCount - 1))
        Debug.Print Key & " has address range " & dic(Key).Address & " to merge"
    Chirag R Raval likes this.
  5. monoj chakraborty
    27
  6. Chihiro
    3,316
    Use the 2nd code then. Since dictionary stores the range object itself.
    "dic(Key).Merge" will work same as Range("Cell:Cell").Merge
    Code (vb):
    Sub Demo()
    Dim cel As Range
            If rCount > 1 Then
        dic(Key).Merge
Share This Page
