VBA Array Code
Hi Team,
I need your help to provide a code which will check if there is an item # entered and nothing about its descriptions will pop up a Msg Box saying that specific Item # description is not entered , if there are Msg Box Saying There are multiple Items # with Description.
The Array range should be from C5 :C25 .
Attached is the sample File
  • Sample file.xlsx
Just to keep it more simple the code to run through for those cells which are not blank in range C5 :C25 and then check if the respective cell in column D is not bank for the cells in whic are filled with data. If found then pop up a MSG box
Sub Looper()
Dim MyItems As String
Dim LstRow As Integer
'Count last non blank row in column C
LstRow = Cells(Rows.Count, "C").End(xlUp).Row
'Start Cell
Range("C5").Select
'Loop for Item with no Description
For i = 5 To LstRow 'Change the 5 to whatever is your start row
    If ActiveCell.Offset(0, 1) = "" Then
        If Len(MyItems) = 0 Then
            MyItems = ActiveCell
            MyItems = MyItems & ", " & ActiveCell
'Messagebox at end
    MsgBox "All items have descriptions", vbInformation, ""
    MsgBox "Below item# need descriptions:" & vbNewLine & vbewline & MyItems, vbCritical, ""
  • Sample file.xlsx
Dear Chirayu,
you forgot to save file in macro enabled sheet,
i have updated your attachment and uploaded here.
  • Sample file (4).xlsm
Dear Chirayu,
I never add my code to .xslm files unless expressly stated otherwise by thread creator. I just work on the sample file provided & upload the code
Then I misunderstood, sorry
Small edit required in your code, "i" need to be declared, it popped error msg for me. May be because of Open Explicit line at top.
There is typo in last msg box, vbnewline, ( Second) reading wrong.
-Ashwin
Hi Team,
Code is really helpfull, but i was thinking that i would get something on Array , if there could be something as such would be great .
Also i have one question on the VBA Before close event of the work book , can this code be called or triggered from a Module instead of THISWORK.
Hi !
Message box demonstration using Excel basics
and working whatever the module :​
Sub Demo()
'                Dim V    ' Variant array only with Option Explicit, useless without
    With Sheet1
        .Activate
        V = Filter([TRANSPOSE(IF(D5:D25="",IF(C5:C25>0,ADDRESS(ROW(D5:D25),4,4))))], False, False)
        If UBound(V) > -1 Then
            .Range(V(0)).Select
            MsgBox "Missing in " & Join(V, " & "), vbExclamation, "  Item Description"
Hi !
Sub Demo()
    With Sheet1
        .Activate
            .Range(V(0)).Select
Could you please provide an understanding of filter option and the 4,4 referring to that is used in Code.
Raghava.
Hi Raghava@rock
The Address function has five parameters : the first, second are not optional where the third / fourth / fifth are optional
1- The first parameter is row number and as provided it would produce the row numbers for the range D5:D25
2- The second parameter is column number which is here 4 that refers to column D
3- the third which is optional here is 4 which gives relative address like that D5 / D6 and so on
1 = Absolute
2=absolute row / relative column
3= relative row / absolute column
4=relative
Hope this helps you
Hi
I made some adjustments to the provided code as my requirement .
E = Filter([TRANSPOSE(IF(B64:B183="",IF(F64:F183="YYY",IF(G64:G183>0,ADDRESS(ROW(G64:G183),2,4)))))], False, False)
While i am trying to add another condition IF(F64:F183="XXX" it is throwing an error.
Please help.
You have 2 values to test on exactly the same range
so it could be difficult to follow this formula way.
As we don't have any sample workbook in relation with this need …
Within the IF for the range, try an OR operator between both values …
According to Mr. Marc L post
this may be like that
E = Filter([TRANSPOSE(IF(B64:B183="",IF(OR(F64:F183="YYY",F64:F183="XXX"),IF(G64:G183>0,ADDRESS(ROW(B64:B183),2,4)))))], False, False)
Hello ,
This time i need the same with AND criteria attached is the file . below is the code I changed , like always its not working ....
V = Filter([TRANSPOSE(IF(D5:D25="",IF(AND(B5:B25="All",C5:C25>0),ADDRESS(ROW(D5:D25),4,4))))], False, False)
Do not use AND operator but IF within an IF in formula.
As I didn't succeed with AND within an array via Evaluate method,
I suppose it's the same for OR operator …
By the way, it would be easier for you to go to classic VBA way
like Chirayu's post. And instead of an array you could use a string variable
to work with the message box …
MsgBox Join(Filter([transpose(if((b5:b1000="All")*(c5:c1000>0)*(d5:d1000=""),address(row(b5:b1000),4,4),char(2)))], Chr(2), 0), vbLf)
Quite a few worksheet functions do not work with evaluate method with array.
And Or...etc, I would really like to see if they work...
If you want to learn a bit of Evaluate Method, the link is the thread I first introduced as a solution for someone.
http://www.mrexcel.com/forum/excel-questions/246143-macr-change-positive-values-negative.html
pgc01 is giving good explanation.
Few more detailed example.
http://www.ozgrid.com/forum/showthread.php?t=183815
Hi Marc L,
I have used the provided code (arrayone) , but this time the change is that my column D is with merged cell but filled with required information but code is still picking the all cells except the first cell of the merged one which has value .
Could you please help me provide the code to pick only the address of first merged cell with out any text in it while Coulmn "C have value.
Just one more point to note that merged cells will be always 3 cells
Thanks a ton in advance
Raghava
  • Sample file1 (4).xlsm
That way can't be used with merged cells !
Again, you must go to classic way like Chirayu's post …
Sub test()
    With [c4].CurrentRegion
        With .Offset(1).Resize(.Rows.Count - 1).Columns(2)
            MsgBox Join(Filter(Evaluate("transpose(if((mod(row(1:" & .Rows.Count & "),3)=1)*(" & .Address & _
            "=""""),address(row(" & .Address & "),4,4),char(2)))"), Chr(2), 0), vbLf)
Great formula jindon !
But he asked in his last attachment for D23,
the reason why I didn't really undersand its need …
My bad … 'cause I am under 2003 I had to copy data to a new workbook
and I didn't saw that first displayed row was #2 instead of #1,
the reason why I was confused and couldn't understand its need …
This works as per requirement , Jindon i kindly request you to provide explain the formula so that i have some learning too :)
Hey Could some Explain the below formula used ?
