VBA & [CODE] Tags
chirayu
Hi All,
Was wondering something with regards to VBA & CODE tags.
Majority of my code is indented. However I noticed that when I copy my code to the forum & paste it into the thread. My indents disappear & the code looks like a huge chunk, rather than respective bits and pieces. Does this happen to you & is there a fix other than manual re-edit on forum? Example:
Should be something like this:
Sub Something()
IF Blah = Blah Then
    'Do Something
    Do Until Blah
       If Not IsEmpty(Blah) Then
            'Do Something more
   Loop
    'Do Nothing
But instead shows up like this:
Sub Something()
IF Blah = Blah Then
'Do Something
Do Until Blah
'Do Something more
Loop
'Do Nothing
No, it keeps indentations for me just fine...your source code, is it properly indented? You're using basic VBE and copy/paste right, not something like Notepad++ or something else? o_O
No, Direct Copy/paste doesn't encounter so far...
Sub get_data()
Dim ws As Worksheet, cFind As Range
For Each ws In ThisWorkbook.Worksheets
If ws.Name <> "I want Result like this." Then
    Set cFind = ws.Cells.Find("txn #")
        If Not cFind Is Nothing Then
            With cFind.CurrentRegion
Rechecked!!
Sub get_data()
                .Offset(1).Resize(.Rows.Count - 1).Copy
Oh ok so I need to use code window? I usually just use the tags directly by typing them. Works with the window but not direct tags.
Sub SAMPLER()
'Save this as XYZ.CSV & send to ABC@123.com
If MsgBox("Would you like to create the XYZ.csv file", vbYesNo, "") = vbNo Then
    MsgBox "Macro Cancelled. Macro will now exit.", vbCritical, ""
    Exit Sub
Dim DWIP As String
Dim NewWB As String
