Vba code to have multiple warning sheets visible in protected workbook
ichristan21
Hi everyone,
I found the below code online and was able to integrate it in my workbook however the code is able to open only one warning sheet (Dashboard), this warning sheet is the only sheet that is kept visible during workbook open and workbook beforeclose event. Could anyone help me to modify the code to have multiple warning sheets? Warning Sheet to be Visible must be Sheets Sem1 Database, Sem2 Database, Sem3 Database and Dashboard, other sheet kept hidden. THANKS!
[Option Explicit]
Option Compare Text
Dim oSht As Object
Dim ws As Worksheet
Dim cControl As CommandBarButton
Private Const MaxUses As Long = 20  '<- change uses
Private Const wsWarningSheet As String = "Dashboard"
Private Sub Workbook_BeforeClose(Cancel As Boolean)
'hide all sheets except warning sheet
    For Each ws In ActiveWorkbook.Sheets
    Application.ExecuteExcel4Macro "Show.ToolBar(""Ribbon"", False)"
    ThisWorkbook.Protect Structure:=False, Windows:=False, Password:="ÔÔ;<«Ð71ÏвU#¶evyÿBë"
        If ws.Name = wsWarningSheet Then
            ws.Visible = True
        ws.Visible = xlVeryHidden
    'record opening in remote cell
    Sheets("Dashboard").Range("A2") = ""
    Application.GoTo Reference:=['Dashboard'!A1]
    With ActiveWindow
        .DisplayHeadings = False
        .DisplayZeros = False
        .DisplayHorizontalScrollBar = False
        .DisplayVerticalScrollBar = False
        .DisplayWorkbookTabs = False
    With Application
        .DisplayFormulaBar = False
        .DisplayStatusBar = False
    With Sheets(wsWarningSheet).Cells(Rows.Count, Columns.Count)
    frmPassword.Show vbModeless
    Application.Visible = False
[/End Sub]
[Private Sub Workbook_Open()]
    Dim ws As Worksheet
'Limit Scrolling Area in worksheets'
    Worksheets("Matrix").ScrollArea = "A1:Y115"
    Worksheets("Settings").ScrollArea = "A1:AC66"
    'Worksheets("Sem3 Database").ScrollArea = "A1:AI506"
    'Worksheets("Sem2 Database").ScrollArea = "A1:AI506"
    'Worksheets("Sem1 Database").ScrollArea = "A1:AI506"
    'Worksheets("Sem1").ScrollArea = "A1:AAP502"
    'Worksheets("Sem2").ScrollArea = "A1:AAP502"
    'Worksheets("Sem3").ScrollArea = "A1:AAP502"
        For Each ws In ActiveWorkbook.Worksheets
            If ws.Name <> "Dashboard" Then
                ws.Visible = xlSheetVeryHidden
        Next ws
        With ActiveWindow
        ActiveSheet.Protect Password:="ÔÔ;<«Ð71ÏвU#¶evyÿBë", AllowFiltering:=True, AllowFormattingColumns:=True, AllowFormattingRows:=True, AllowSorting:=False, UserInterFaceOnly:=True
        With Application
[/End Sub]
