VBA code to lookup and fill across
Im trying to write a VBA code for lookup few words in a range of cells.
There was no success and end up in recording macro and below mentioned is the code (Using record Macro)
Sub normallookupstyle()
Selection.FormulaR1C1 = "=VLOOKUP(RC[-1],{123;""23KC"";""Animal"";""Planet"";""Split"";""Layout""},1,0)"
Selection.Copy
Selection.PasteSpecial Paste:=xlPasteValues, Operation:=xlNone, SkipBlanks:=False, Transpose:=False
I have mentioned the un-successful code below (As im not good in VBA coding)
Sub codingstylelookup()
Dim lookrange() As Variant
lookrange(123,""23KC"",""Animal"",""Planet"",""Split"",""Layout"")
ActiveCell.Value = Application.WorksheetFunction.VLookup(ActiveCell(0, -1).Value, lookrange, 1, 0)
Please help me out with a correct VBA code for the code i have highlighted in red color
I would like to fill across the range between B2 to B18 (File attached)
Mr. Excel Question Board link:
http://www.mrexcel.com/forum/excel-q...ll-across.html
Excel Forum link:
http://www.excelforum.com/showthread...14#post4331014
  • Test file.xlsm
Hi:
Try the following code:
Dim lookrange As Variant
Dim str$
lookrange = Array(123, "23KC", "Animal", "Planet", "Split", "Layout")
For i& = LBound(lookrange) To UBound(lookrange)
    str = Cells(ActiveCell.Row, ActiveCell.Column - 1).Value
    If str = lookrange(i) Then
    ActiveCell.Value = lookrange(i)
    Exit For
    ActiveCell.Value = "N/A"
