VBA-Copy and paste a range of data into column of a chosen date
Michael Mares
I'm having trouble trying to figure out how to get the following procedure done through the use of a Macro. I have a range of data, lets call it G24:G36, that I would like the values pasted into the corresponding date on to a table that has a list dates listed in row 1. The date would be based on the date that is selected in cell D22.
I've seen similar posts that pasted data onto another sheet and in a different way but I just can't figure out how to apply it in this situation.
I attached a simplified version of what I'm trying to accomplish.
I've done research upon research and I am completely stuck. I appreciate any help ya'll can offer.
Thanks in advance!
  • Sample1.xlsx
Hi Michael,
Why use vba when this could be resolved using excel function? See attached file for example.
Kind regards,
A!
  • Sample1.xlsx
Hello! Thanks for your response!
I thought about using a similar formula but I my intent is to store the data and re-use the field for the next day. Using the formula approach, I would either have to type the data in anyways or do a paste as values. For what it's worth, I used the January date as an example.
Though it's a rather simple objective, it's something I would use for other purposes, several times a day.
Hi !
How to find date in row #1 :​
Sub Demo()
    With Sheet1
           D# = 2 + .[D22].Value2 - .Cells(2).Value2
        If D > 1 Then
            With .Cells(D)
                If IsDate(.Value) Then MsgBox .Address
