VBA: Extract Amt from String
Hello Chihiro..
Really impressed with the short code provided by you.
I have few challenges which i have not noticed earlier.
Below are the challenges facing
Assuming following pattern is what is needed to be extracted.
digits[dot]digits
Pattern then is "\d+\.\d+". Didn't consider negative value as sample had "-550.600" but extracted as "550.600"
Sub Demo()
Dim cel As Range
With CreateObject("VBScript.RegExp")
    .Pattern = "\d+\.\d+"
    For Each cel In Range("A2:A" & Cells(Rows.Count, "A").End(xlUp).Row)
        If .Test(cel.Value) Then cel.Offset(, 2) = CDbl(.Execute(cel.Value)(0))
If not familiar with RegEx, you can use following site to test patterns.
https://regex101.com/
Can you upload file with all possible patterns? Original code is meant to extract number with decimal separator only.
FYI - If all patterns contain currency codes. It's probably easier to use that.
Ex. Below is pattern for ISO 4127 Currency Codes (simple list created from ISO documentation).
(AED|AFN|ALL|AMD|ANG|AOA|ARS|AUD|AWG|AZN|BAM|BBD|BDT|BGN|BHD|BIF|BMD|BND|BOB|BOV|BRL|BSD|BTN|BWP|BYR|BZD|CAD|CDF|CHE|CHF|CHW|CLF|CLP|CNY|COP|COU|CRC|CUC|CUP|CVE|CZK|DJF|DKK|DOP|DZD|EGP|ERN|ETB|EUR|FJD|FKP|GBP|GEL|GHS|GIP|GMD|GNF|GTQ|GYD|HKD|HNL|HRK|HTG|HUF|IDR|ILS|INR|IQD|IRR|ISK|JMD|JOD|JPY|KES|KGS|KHR|KMF|KPW|KRW|KWD|KYD|KZT|LAK|LBP|LKR|LRD|LSL|LTL|LVL|LYD|MAD|MDL|MGA|MKD|MMK|MNT|MOP|MRO|MUR|MVR|MWK|MXN|MXV|MYR|MZN|NAD|NGN|NIO|NOK|NPR|NZD|OMR|PAB|PEN|PGK|PHP|PKR|PLN|PYG|QAR|RON|RSD|RUB|RWF|SAR|SBD|SCR|SDG|SEK|SGD|SHP|SLL|SOS|SRD|SSP|STD|SVC|SYP|SZL|THB|TJS|TMT|TND|TOP|TRY|TTD|TWD|TZS|UAH|UGX|USD|USN|USS|UYI|UYU|UZS|VEF|VND|VUV|WST|XAF|XAG|XAU|XBA|XBB|XBC|XBD|XCD|XDR|XFU|XOF|XPD|XPF|XPT|XSU|XTS|XUA|XXX|YER|ZAR|ZMW|ZWL)$
Hello Chihiro.
Here is the attached file with examples...Rest all looks fantastic.
Thanks for your time.
  • Convert.xlsb
Best solution but only thing is i need to mention the currencies unlimited..
but really works for all my challenges.
Private Sub Get_Sums()
    With ActiveSheet
        Dim chks(3)
        chks(0) = "USD."
        chks(1) = "USD-"
        chks(2) = "GPB:"
        chks(3) = ".CNY"
        y = 2
        Do
            .Cells(y, 3) = Empty
            chk_a = .Cells(y, 1)
            For c = 0 To 3
                Err.Clear
                cutX = WorksheetFunction.Find(chks(c), chk_a, 1)
                If Err.Number = 0 Then
                    .Cells(y, 3) = Mid(chk_a, cutX + 4, 12)
                    .Cells(y, 3).NumberFormat = "0.000"
                    c = 99
            Next c
            y = y + 1
        Loop Until .Cells(y, 1) = Empty
    MsgBox "DONE"
Something like this ?
There were 4 kind of 'amounts', none negative(?).
Press [GET]
What system is this data taken from? Never seen this bad of pattern inconsistency from single source.
At any rate, try below.
Sub Demo()
Dim myArr
myArr = Range("A2:A" & Cells(Rows.Count, "A").End(xlUp).Row).Value
For i = 1 To UBound(myArr)
    For j = Len(myArr(i, 1)) To 1 Step -1
        tVal = Mid(myArr(i, 1), j, 1)
        If IsNumeric(tVal) Or tVal = "." Then
            res = tVal & res
        ElseIf tVal = "," Then
                .Pattern = "(USD|GPB|CNY)"
                If Not .Test(myArr(i, 1)) Then
                    myArr(i, 1) = ""
                    res = ""
                    Exit For
                    myArr(i, 1) = IIf(InStr(1, res, ".") = 1, Replace(res, ".", "", 1, 1), res)
                    res = ""
                    Exit For
Range("C2").Resize(UBound(myArr)) = myArr
Monty
You haven't send more data or have You?
My '#31' code has made just from You original data; seven rows.
If You could sent more data then You could get another code which would have more currencies.
digits[dot]digits
Sub Demo()
Dim cel As Range
This is the best could I believe with using any currency s
Sub Demo()
Dim myArr
            res = tVal & res
                    myArr(i, 1) = ""
                    res = ""
                    Exit For
                    res = ""
                    Exit For
Thanks for your efforts...But to mention all the available currency s....In the code... Trying to find modified short code you provided where you have mentioned currencies...
Then use this.
Sub Demo()
Dim myArr
            res = tVal & res
        ElseIf tVal = " " Then
                myArr(i, 1) = ""
                res = ""
                Exit For
                res = ""
                Exit For
Note: In your sample there is no space after currency code so it works. If there is instance where currency code is followed by a space before the amount. This will fail.
Also this using RegEx.
Sub Demo()
Dim myArr, i As Long
    .Pattern = "(\d+\.\d+|\d+\.|-\d+)$"
    .Global = True
        myArr(i, 1) = Replace(myArr(i, 1), ",", "")
        If .Test(myArr(i, 1)) Then
            myArr(i, 1) = Replace(.Execute(myArr(i, 1))(0), "-", "")
            myArr(i, 1) = ""
Again if pattern changes from your sample, you will likely need to modify it.
Wow chihiro...You are awsome without currency code mentioning we are able to get the results but it fails at only one point.
DEBIT-HSEP HTA-DEVELOPMENT 2017-04.USD530
for the above case no result and these kind of lines are many in the raw data...can you please help me.
Sub Demo()
    .Global = True
            myArr(i, 1) = ""
So that's a new pattern not found in your sample.
This is going to add extra layer of complexity, since pattern \d+ is going to match both of following.
FOR S115 PROPERTY ACC FOR JUNE 2017
Since, you don't want to list patterns for currency code... You could add pattern [A-Z]\d+, but that's going to extract D530, and requires additional check/process in code.
Just use the code in post #37, that one will accommodate for your new pattern.
If you really must use RegEx... try something like...
Sub Demo()
    .Pattern = "(\d+\.\d+|\d+\.|-\d+|[A-Z]\d+)$"
    .Global = True
            If IsNumeric(Left(.Execute(myArr(i, 1))(0), 1)) Then
                Debug.Print i & "," & Left(.Execute(myArr(i, 1))(0), 1)
                myArr(i, 1) = .Execute(myArr(i, 1))(0)
            ElseIf Left(.Execute(myArr(i, 1))(0), 1) <> " " Then
                myArr(i, 1) = Replace(.Execute(myArr(i, 1))(0), Left(.Execute(myArr(i, 1))(0), 1), "")
            myArr(i, 1) = ""
