    Hi Guest,
    Yours,
    Chandoo
  2. Hi All
VBA Macro For Configuration
Discussion in 'VBA Macros' started by devendra.dvm, Feb 27, 2017.
  1. devendra.dvm
    devendra.dvm Member
    139
    Hi Experts,
    Please help me with VBA Macro to configure commission rates..
    Have attached sample for reference..
    In Configure sheet...I have mentioned instruction details and agents
    In output Sheet.. I have mentioned wat is the output will come out after i click upload button in Configure sheet......Hope you will understand the same.
    Thanks in Advance...
  2. Monty
    Monty Well-Known Member
    802
    Hey Dev..
    Not so clear!
    Arpanakumar and jamesexcel1970 like this.
  3. Monty
    802
    Please confirm the format below is it as per your requirment and also let me know what you are looking for?
  4. Monty
    802
    Dev!
    Little change in the format for easy reading
  5. jamesexcel1970
    jamesexcel1970 Member
    85
    Wow Monty, Onces again you are ready with frame.
    devendra.dvm and Monty like this.
  6. devendra.dvm
    devendra.dvm Member
    139
    Hi Monty Thanks for your quick response...
    Please refer the below image for the same.
  7. devendra.dvm
    devendra.dvm Member
    139
    Hi James,
    Hope you also will understand wat is my requirement with references which i have provided..
    Thanks in advance.
  8. Monty
    802
    Dev.
    Did you chk the format provided.?
    You don't' have time it seems to explain...asking us to refer image..Which we hardly understand.
  9. devendra.dvm
    devendra.dvm Member
    139
    Yes Monty...
    Have checked the format and that's the reason i have posted images for your reference..
    It's not that i don't have time.
    I Have explained the same in that screenshot..you can see that i wrote in highlighted cells.
  10. Monty
    802
    Quick question.
    When i select one agent you wanted to show as output 3 rows as per the broker id table?
  11. devendra.dvm
    devendra.dvm Member
    139
    yes..
    if u select one agent with scheme TR
  12. devendra.dvm
    devendra.dvm Member
    139
    in the same way if u select scheme MM output will be in 7rows
  13. Monty
    802
    Please confirm it.
    MM ->7 rows
    FS -> 7 rows
    TR-->3 rows
    if you select one agents then total rows to be displayed would be 17 rows.
  14. devendra.dvm
    devendra.dvm Member
    139
  15. devendra.dvm
    devendra.dvm Member
    139
    Hi Monty
    hope your online now.
  16. devendra.dvm
    devendra.dvm Member
    139
    Hi Monty.
    Pls respond..thank You..
  17. Monty
    802
    Hey Dev.
    Sorry to keep you in waiting.
    Still working on it and even busy with office work too..
    may be need to buy some time from you.
  18. devendra.dvm
    devendra.dvm Member
    139
    Tkank you Monty...
  19. devendra.dvm
    devendra.dvm Member
    139
    Hi Monty.
    Hope you will come to online today...
  20. devendra.dvm
    devendra.dvm Member
    139
    Hi Monty.
    Pls respond.
  21. Monty
    802
    Still trying my level best to get the output into shape but unsuccessful..let me keep trying...need to buy time again.
    jamesexcel1970 and Arpanakumar like this.
  22. devendra.dvm
    devendra.dvm Member
    139
    Thank you Monty.
    Sorry to bug you again about this.
  23. devendra.dvm
    devendra.dvm Member
    139
    hi Monty.
    Hve found any solution..?
  24. Monty
    802
    Still Unsuccessful after many test....Not really sure to crack it..
  25. devendra.dvm
    devendra.dvm Member
    139
    Hi Monty
    Thanks for reply....Hope you will crack it...:(
Share This Page
