VBA Macro For Configuration
ohh..:( my bad luck
your the only hope for me...still thanks alot monty for your time..
hope u vl get a solution...tnank you.
Hi Monty.
I would like to inform you that i have posted the same project in other forum also....i let u know if i get any result and i will share the details...
Hope you will understand..
yes perfect...Please consider below three points also.
1) Required Clear button
2) Need an option to add scheme codes
3) Need an option to select Agent codes.
Thanks in advance
Hows this
The two tables are tables and so just Type new values below the existing data
I can change the sort order of the Output if you require also
  • Sample @ Dev.xlsm
Hi Hui,
I have checked the attachment and its working fine but in output result getting as TRUE and FALSE in column A instead of scheme codes..
And is any other way to select Agents codes instead of drop down list...
My suggetion :
Type 1: Double click on agent code to select Agent codes.. (Agent code should become BOLD once double click on agent code
Type 2: Make a drop down list (Filter ) directly on agent codes to selct multiple agent codes.
Yes please make changes in output sort order as
First Scheme level:
MM
FS
TR
Hui
Then Broke Type ID:
1
2
3
10
11
84
85
Thanks in advance.
Hi Monty..
Thanks for your reply...i have checked your file...still there is problem in column A all agent codes are getting updated instead of Scheme codes.. In column A Schemes codes should come..rest all correct
Thanks Monty..
But still getting updated wrong values..In Column A these Schemes Codes should come
May be this small change will help for the same
.Cells(x, 1) = wss.Cells(Scheme, 7).Value
Now working fine after that small change in code.. Thanks monty..
Please make changes as i requested in earlier post..
My suggetion :
First Scheme level:
MM
FS
TR
Hui
Then Broke Type ID:
1
2
3
10
11
84
85
Of course your right Monty.
But some i need to configure rates to more than 50 Agents so selecting multiple Agents with True, False will make confusion...
May be Filter option for selecting Multiple Agents is good idea in my opinion...
