Hi
I have a series of hr reports, although these vary the column with the employee number in it does not change. If I were to highlight a cell in the primary workbook can I get excel to highlight the cells in other workbooks? In that way I can find and delete unwanted data from the various workbook.
I basically want to find all hr employees and remove their records from the reports on the different workbooks.
I thought maybe the easiest approach to this would just be some way of highlight in a colour the records I want to remove in the main workbook and then all the sub workbooks have that matching cell contents hightlighted in the same cell so I can filter on colour and remove the unwanted rows for each of the sub workbooks.
Is this possible?
Kind Regards
Ben
Is this possible?
Kind Regards
Ben
