VBA to split fullname to first and last and clean any trailing spaces
IKHAN
Excel wizards need macro help on splitting fullname to seperate columns (Firstname and lastname) from (2. planning) tab and copied to (4. mobile) tab in column D and F from line 18, Need to clean any trailing spaces,If name seperated by semicolon,second name to be copied in next row and Delete last row if duplicate first and last name found (in attached ex. line 28) and update (4. mobile)tab automatically as data full name is entered in (2. planning) tab or selected from drop down list.
Can this be done in vba?
  • Test.xlsx
Right click on the 2nd Sheet tab and choose option view code. Test this on a backup. It will run only when you make changes to column C on sheet 2. It is basic logic, edit where you need to.
Dim objDict As Object
Dim varData, rowData, varKey
Dim varOut()
Dim i As Long
If Target.Column = 3 Then
    On Error GoTo EoSub '// Just in case something fails
    Sheets("4. Mobile").Range("D18").CurrentRegion.ClearContents
    varData = Sheets("2. Planning").Range("C2:C" & Sheets("2. Planning").Range("C" & Rows.Count).End(xlUp).Row).Value
    Set objDict = CreateObject("Scripting.Dictionary")
    objDict.Comparemode = vbTextCompare
    For i = LBound(varData) To UBound(varData)
        rowData = Split(varData(i, 1), ";")
        For j = LBound(rowData) To UBound(rowData)
            If Not objDict.exists(Application.Trim(rowData(j))) Then
                objDict.Add Application.Trim(rowData(j)), Trim(rowData(j))
        Next j
    ReDim varOut(objDict.Count - 1, 0 To 1)
    i = 0
    For Each varKey In objDict.keys
        varOut(i, 0) = Split(varKey, " ")(0)
        varOut(i, 1) = Split(varKey, " ")(1)
        i = i + 1
    Sheets("4. Mobile").Range("D18").Resize(UBound(varOut) + 1, 2).Value = varOut
EoSub:
Dim varOut()
Dim i As Long
        Next j
    i = 0
        i = i + 1
EoSub:
It works on my backup sheet..
Having problem with my orginal sheet.
Running another code on (2. Planning) tab for to select mutiple items from dropdown list in column C (see below code)
Getting error message ambigous name
Dim rngDV As Range
Dim oldVal As String
Dim newVal As String
If Target.Count > 1 Then GoTo exitHandler
Set rngDV = Cells.SpecialCells(xlCellTypeAllValidation)
On Error GoTo exitHandler
If rngDV Is Nothing Then GoTo exitHandler
If Intersect(Target, rngDV) Is Nothing Then
  newVal = Target.Value
  Application.Undo
  oldVal = Target.Value
  Target.Value = newVal
  If oldVal = "" Then
  If newVal = "" Then
  Target.Value = oldVal & "; " & newVal
exitHandler:
MOD Edit: Code Tags Added.
You'd need to combine 2 codes in same Worksheet_Change event.
As you can have only one Worksheet_Change event.
Just copy and paste Shrivallabha's code below existing one (I'd move Dims to top though) and test.
However, there may be some conflict, but hard to trouble shoot without having your set up. It'd help if you upload sample setup with data validation etc.
1) To ThisWorkbook code module
Private Sub Workbook_Open()
    Run Sheets("4. mobile").CodeName & ".worksheet_activate"
2) To "4. Mobile" sheet code module
Private Sub Worksheet_Activate()
    Dim a, i As Long, e
    a = Sheets("2. Planning").Columns("c").SpecialCells(2).Value
        .CompareMode = 1
        For i = 2 To UBound(a, 1)
            a(i, 1) = Application.Trim(a(i, 1))
            If a(i, 1) <> "" Then
                For Each e In Split(a(i, 1), ";")
                    .Item(Trim$(e)) = Split(Application.Trim(e))
        a = Application.Index(.items, 0, 0)
    With [d18:e18]
        .Resize(Rows.Count - .Row - 1).ClearContents
        .Resize(UBound(a, 1)).Value = a
  • Test with code.xlsm
uploaded original file ...
Above code doesn't run original file
tab 2.planning fullname to be split first last name
  • testfile.xlsm
@ Jindon...Your code works well but not on my worksheet , which had data validations..Kindly have a look at the latest attached file.
when copied to another spreadsheet ,Getting "Run time error Type-mismatch 13" and stops at highlighted RED
Any suggestion??
Dim a, i As Long, e
.CompareMode = 1
With [d18:e18]
Copy?
Change to this anyway
    Dim r As Range, a, i As Long, e
    With Sheets("2. Planning")
        If .Range("c" & Rows.Count).End(xlUp).Row > 12 Then
            a = .Range("c12", .Range("c" & Rows.Count).End(xlUp)).Resize(, 2).Value
    If IsArray(a) Then
            .CompareMode = 1
            a = Application.Index(.items, 0, 0): i = .Count
    With [d18:e18]
        If IsArray(a) Then
            .Resize(i).Value = a
You already have a working solution. Test this on a backup. I have added my code to the code you've posted. Remove my code from the module. Replace the old code with this code.
Dim rngDV As Range
'\\ New Declarations start
Dim varOut()
Dim i As Long
'\\ New Declarations end
'\\ For any errors in existing code we'll jump straight to new code
If Target.Count > 1 Then GoTo ColumnCCode
On Error GoTo ColumnCCode
If rngDV Is Nothing Then GoTo ColumnCCode
  Application.Undo
  If oldVal = "" Then
  If newVal = "" Then
'\\New code start
ColumnCCode:
    On Error GoTo exitHandler '// Just in case something fails
        Next j
    i = 0
        i = i + 1
'\\ New code end
exitHandler:
Works fine if full name is entered , Gives "run time error type mismatch 13" on highlighted in RED, when just firstname is entered.
If no spaces or just single(first\lastname) entered in Column "c" ,should copy to First name column D in Tab (4. Mobile)
Really Appreciate your work....
If IsArray(a) Then
.CompareMode = 1
With [d18:e18]
If IsArray(a) Then
That probably has to do with Single Name situation you have informed. Please test with below code.
Dim rngDV As Range
Dim varOut()
Dim i As Long
  Application.Undo
  If oldVal = "" Then
  If newVal = "" Then
'\\New code start
ColumnCCode:
    Sheets("4. Mobile").Range("D18:E" & Sheets("4. Mobile").Range("D" & Rows.Count).End(xlUp).Row).ClearContents
        Next j
    i = 0
        varOut(i, 0) = Split(varKey & " ", " ")(0)
        varOut(i, 1) = Split(varKey & " ", " ")(1)
        i = i + 1
'\\ New code end
exitHandler:
    Dim r As Range, a, i As Long, e, x
    If IsArray(a) Then
            .CompareMode = 1
                        x = Split(Application.Trim(e))
                        ReDim Preserve x(1)
                        .Item(Trim$(e)) = x
    With [d18:e18]
        If IsArray(a) Then
Slight modification is reqd. on below code - Based on name in column D and F in "2. mobile" info is pulled from other sheet thru formulas/ vlookup and fillup data in row or info entered manually if missing against the name in the row.
Above Macro is entering name correctly, but deletes any data manually entered info in row "2. mobile" sheet and also if another name is entered only column D and F gets added up and info entered previously againist tht name gets mismatched.
ex : name entered Tom Kasik in column D and F in "2. mobile" pulls info from other sheet and fillup the row with phone number. If any data is entered manually ex :(number changed) in tht row and new name gets added /deleted..there's mismatch.
    If IsArray(a) Then
            .CompareMode = 1
                        ReDim Preserve x(1)
                        .Item(Trim$(e)) = x
    With [d18:e18]
        If IsArray(a) Then
