This is my vision and what I am trying to create. I will be as detailed as possible. Some one this information is a conversation between a programmer and myself:
I have
I need to perform
Need to know
Code requirements
As a "Project Designer," it was suggested in the following scenario
In a location of your choice:
Folders and Files
The Fiscal Ends Tasks
UserForm notes
From the view point of the Employee:
When they open their Assignment workbook, A Data Entry Form is displayed with all open assignments listed. When they click an Assignment in the list (by name, date/time, case number, or however you want them listed.)
All pertinent information in re that case is magically displayed in the most convenient layout for their work. While entering dfate, sometimes they just click a button and the pertinent value is automatically entered, sometimes they select a value from a list, and sometimes they have to actually type in a value.
At the end of their work on a case, the click a button named Done or one named Next Case, or even just click another name in the List of Cases.
If there are no more cases in the list, they click a button name Refresh and like magic, the list fills up again. at the end of the day, they click a button named Close Workbook or Exit.
From a Supervisors Viewpoint:
When he opens her Supervisor Workbook, a "Control Panel" magically appears where he can select to View Master Log, or Make Assignments.
When she selects Make Assignments, a Data Entry Form appears with a list of all employees he is responsible for. There is also a button named View all Employees, (this allows any Supervsor at that computer to make assignments for any Employee.)
She then selects an Employee from the list and a Data Entry form appears that operates just like the one in the Employee's Assignment book.
When done with that Employee, he can click one of several buttons, Save, Close, Exit, Next Employee, Back to Control Panel, View Master Log, or as you want.
From the viewpoint of the Project Designer:
All UserForms shall be designed from the viewpoints of the User and the Business goals. Period.
Make the Users tasks as easy and simple as possible. Accomplish all the Businesses' goals, include preventing as many preventable data entry errors as possible.
http://www.vbaexpress.com/forum/sho...-code-to-transfer-data-to-different-workbooks
I have
- WorkBook named "Master Log"
- Where X = Number of employees
- Master Log has 2 + x sheets
- Sheet1.Name = "Master Log"
- Sheet2.Name = Reference
- Sheets(n thru X +2) are named in pattern Employee(n).Name
- You also have X (+ exEmployee.Count) Workbooks also named Employee(n).Name
- Workbook Employee(n).Name has one sheet also named Employee(n).Name.
I need to perform
- Transfer data from Certain Ranges in
- Book Master Log, Sheet Employee(n).Name
- to Book Employee(n).Name, Sheet Employee(n).Name
- Book Employee(n).Name
- to Book Master Log, Sheet Employee(n).Name
Need to know
- Everything is stored and saved to on the same network and in the same folder, The master may be moved to another folder but all workbooks will be saved in the same S: drive.
- what triggers each transfer
- I'll explain how the work is completed and what the workers and supervisors do: The supervisors will be assigning cases to each employee in the master log and enter that data on the master log in their corresponding employee's sheet/tab. The data entered will be in columns B-J.
- Then once the employees see their assignments in their own workbook on sheet1 they will complete the case and put their updates to those specific cases on columns K-Q, that data entered needs to be communicated to the master log in the employee's corresponding sheet/tab.
- At the end of the fiscal year the master log will either stay in the same S : Drive, moved to another folder, but in the same drive or deleted. The employees may save their logs, or may delete them.
- At the beginning of the next fiscal year brand new workbooks are created from scratch usually. Which is why it would be great to know this code to be able to make multiple workbooks in the future.
Code requirements
- Yes, all employee workbooks are named after the employee and they all have the exact same listed columns and will be entering similar data.
- Yes, we also need to be able to remove or add new employees to the master log and create new employee sheets and workbooks just in case employees leave sometime throughout the fiscal year.
Folders and Files
- A folder named Templates
- Restricted to Adminstor (and Supervisors?)
- Template_Supervisor.xlsm
- w/UserForm to perform Supervisor's duties.
- Template_Employee.xlsm
- w/UserForm to perform Employee's duties.
- Sheet 1 is named Assignments in all Employee's books
- Template_MasterLog.xlsx
- Copy of Administrator's FiscalEnd.xlsm
- w/UserForm to perform admin tasks.
- Can also include Supervisor's duties UserForm
- A folder named Folder Assignments
- Supervisors Save Employee books here
- Employees Open their workbooks from here
- A folder named Folder Returned
- Employees Save their workbook to here
- Supervisors Open Employee books from here
- A folder named Folder Archives
- Should be retricted to Supervisors and Administrators
- Stores Old Employee books, Named fiscally
- A folder named Folder MasterLog
- Stores MasterLog.xlsx Book(s) (Old Logbooks named Fiscally)
- Supervisor(s) Workbook(s) [Copy(ies) of Template_Supervisor.xlsm]
- Administrator's FiscalEnd.xlsm
- Employees open, complete and save all Employees workbooks to Returned. Do not reopen till OK'ed.
- Supervisors Open all Employee's books, Update MasterLog, Save all Employee's books to Assignments
- Administrator Uses FiscalEnd.xlsm to
- Rename and move all used Workbooks to Archives
- Create new MasterLog.xlsx
- Create new Supervisor('s) Workbook(s) from Template_Supervisor.xlsm in Templates
- Create new Employee books From Template book in Templates, using Employee list from list in a Reference Sheet
UserForm notes
- All UserForms
- Follow all folder Restrictions
- Prevents User from viewing actual worksheets
- Employees UserForm
- Only shows incomplete assignments
- Ability to select specific assignment
- Commands and inputs to perform all Data entry
- Save book command
- Send to Supervisor command
- ? Recover and edit book from Returned Folder ?
- Edit command to edit all entries on all assignments since last "send to supervisor" event
- Supervisor(s) UserForm(s)
- Ability to select specific Employee Book
- Send to Employee command
- Edit command to edit all all Books till in Folder Assignments
- Can View all worksheets in Employee's books and Master_Log book
- ? Can delete completed Assignments from Employee's books ?
- Administrator UserForm
- Can include all or some Employees forms abilities
- Can include all or some Supervisor(s) forms abilities
- All commands and inputs needed to perform all duties and tasks
