Hi Everyone,
Beginner with VBA here. I'm having trouble with a simple macro I'm writing. Everything works as expected except I get errors whether using PasteSpecial(xlPasteValues). I've tried worksheets.range and worksheets.cells. Is it because I'm using Cut rather than Copy?
Thanks.
Thanks.
Dim lRow As Long, lCol As Long, lMax As Long
'Add new row to Ledger
Worksheets("Ledger").ListObjects("tbl_ledger").ListRows.Add
'Find first empty row in Ledger
For lCol = 1 To 3
lRow = Worksheets("Ledger").Cells(Rows.Count, lCol).End(xlUp).Row
If lRow > lMax Then lMax = (lRow - 1)
Next lCol
'Copy input from Dashboard Input Fields to next empty row in Ledger
Worksheets("Dashboard").Range("B2:D2").Cut Worksheets("Ledger").Cells((lMax + 1), 1)
'Convert value to negative, if not already negative
If Worksheets("Ledger").Cells((lMax + 1), 3).Value > 0 Then Worksheets("Ledger").Cells((lMax + 1), 3).Value = Worksheets("Ledger").Cells((lMax + 1), 3).Value * -1
