    Hi Guest,
    Yours,
    Chandoo
  2. Hi All
What's wrong with my loop?
Discussion in 'VBA Macros' started by Bomino, Jun 18, 2017.
  1. Bomino
    Bomino Member
    74
    Hi everyone,
    I need help troubleshooting my code or better yet help with a more efficient solution.
    I wrote a code and it seems not to be doing what it is supposed to do: pulling data from a worksheet (Data) and populate a column in another worksheet (Main) based on value from dropdown. Here is my code:
    Code (vb):
    Sub Retrieval()
        Dim x As Variant, y As Variant
        Dim RptDate As Range
    With Application
        .EnableEvents = False
        .ScreenUpdating = False
        .Calculation = xlCalculationManual
        Lastrow = DATA.Cells(Rows.Count, 1).End(xlUp).Row
      y = 18
        For x = 6 To Lastrow
              If DATA.Cells(x, 2) = MAIN.Cells(2, 8) And DATA.Cells(x, 3) = MAIN.Cells(y, 6) Then
              MAIN.Cells(y, 13) = DATA.Cells(x, 10)
              y = y + 1
        With Application
            .EnableEvents = True
            .ScreenUpdating = True
            .Calculation = xlCalculationAutomatic
    Am I missing something?
    Any help will be much appreciated.
    Thank you.
    I am also attaching a sample file
  2. vletm
    vletm Well-Known Member
    2,708
    Bomino
    How many same dates there should be?
    Dates would be same format (dd/mm/yyyy or mm/dd/yyyy) not mixed.
    ... You would check Your SOW# compare too ... 'which-to-which'.
  3. Bomino
    Bomino Member
    74
    vletm,
    Thank you for helping. There will be at most 14 same dates (or less depending on the data entry) because there are 14 different SOW#.
    The date format is (mm/dd/yyyy). I still can't make it work.
  4. vletm
    2,708
    Dates:
    and why = MAIN.cells(y,6)
    ... anyway cannot ever match with those parameters.
  5. Bomino
    Bomino Member
    74
    Here is the desired output
    Any suggestion as how to make it work?
  6. vletm
    2,708
    Bomino
    I would make it like this ...
  7. Bomino
    Bomino Member
    74
    Thank you vletm.
    I would to understand what I am doing wrong. Any help would appreciated.
Share This Page
