With Statment with for loop
Hi Team,
Below is the code I am using with "FOR loop to concatenate the value in each row of column 2 ,3,4,5.which is taking long time as I have more than 25000 rows.
while I have searched in google WITH Statement is something that I am thinking to sue to get the task done more quick.
For CurrRow = 13 To CurrLastrow
If Sheets("Curr-wk").Cells(CurrRow, 2).Value <> "" Then
    CurrTEXT = Sheets("Curr-wk").Cells(CurrRow, 2).Value & "$" & Sheets("Curr-wk").Cells(CurrRow, 3).Value & "$" & Sheets("Curr-wk").Cells(CurrRow, 4).Value & "$" & Sheets("Curr-wk").Cells(CurrRow, 5).Value
Sheets("Curr-wk").Cells(CurrRow, 1).Value = CurrTEXT
Could you suggest me how to use with statement in this regard or any improvisation to the above code for fast run time.
Mod edit: Code Tags added
You can use arrays to speed this up:
    Dim vDataOut
    Dim vDataIn
    With Sheets("Curr-wk")
        vDataIn = .Range(.Cells(13, 2), .Cells(CurrLastRow, 5)).Value2
        vDataOut = .Range(.Cells(13, 1), .Cells(CurrLastRow, 1)).Value2
    For CurrRow = LBound(vDataIn, 1) To UBound(vDataIn, 1)
        If vDataIn(CurrRow, 2) <> "" Then
            vDataOut(CurrRow, 1) = vDataIn(CurrRow, 1) & "$" & vDataIn(CurrRow, 2) & "$" & vDataIn(CurrRow, 3) & "$" & vDataIn(CurrRow, 4)
        .Range(.Cells(13, 1), .Cells(CurrLastRow, 1)).Value2 = vDataOut
Thank you so much Debaser, that works :)
Could you also , provide the array functionality to the below code as well . below code is trying to identify the duplicate value and make them unique.
Dim myDataRng As Range
    Dim cell As Range
    Set myDataRng = Range("A13:A" & Cells(Rows.Count, "A").End(xlUp).Row)
        Dum = 1
    For Each cell In myDataRng
        ' LOCATE DUPLICATE VALUE(S) IN THE SPECIFIED RANGE OF DATA.
        If Application.Evaluate("COUNTIF(" & myDataRng.Address & "," & cell.Address & ")") > 1 Then
            cell.Offset(0, 0).Value = cell.Offset(0, 0).Value & "$" & "D" & Dum '
          Dum = Dum + 1
    Next cell
    Set myDataRng = Nothing
thanks again for you help in this regard.
Try this:
    Dim n                     As Long
    Dim oDic                  As Object
    Dim vData
    vData = myDataRng.Value2
    Set oDic = CreateObject("Scripting.Dictionary")
    Dum = 1
    For n = LBound(vData, 1) To UBound(vData, 1)
        If oDic.exists(vData(n, 1)) Then
            vData(n, 1) = vData(n, 1) & "$D" & Dum
            Dum = Dum + 1
            oDic(vData(n, 1)) = Empty
    Next n
    myDataRng.Value2 = vData
Hey Debaser,
Thanks a lot , this even works better.... however if you provide me some in detail explanation on what Vdata and value 2 & Odic used for that would realy helpfull .
vData is just a variable to hold the array of cell values in.
Value2 is like Value but doesn't return Date or Currency types - it returns the underlying Double precision value instead. It's also therefore a little faster generally.
oDic is a Dictionary object used to hold the unique values from the range.
