Word string match formula
dmehta
Hey,
I am looking for a formula, that will match text string in two columns, but shall ignore word order.
Example:
Column A Column B
women shoes shoes women
This shall show as match "yes".
Can anybody help?
Thanks!!!
Hi, dmehta!
Welcome to Chandoo forums!
About your question, I can't think of a way of doing it with formulas using standard functions. If you're willing to use macros then a solution may be building a UDF (user defined function) and then using it in a formula.
Regards!
If you're talking about just looking at two cells, this will work:
=IFERROR(IF(AND(FIND("shoe",A1)>0,FIND("shoe",B1)>0),"yes",""),"no")
Hey all,
Thank you!
@azumi, thank you the second row should have shown "no" because "Aplle" isn't in there.
But appreciate it!
You're welcome, the second row isn't "Apple" but "Pie", that's why come to "Yes"
If each column can contain at most two words separated by a space , try this formula :
=IFERROR(IF(SEARCH(A2, B2 & " " & B2), "Yes"), "No")
One more approach based on layout posted by azumi. In cell C2 normally enter following formula and copy down:
=IFERROR(FREQUENCY(-ISNUMBER(SEARCH(TRIM(MID(SUBSTITUTE(" "&B2," ",REPT(" ",99)),ROW($A$1:INDEX(A:A,LEN(B2)-LEN(SUBSTITUTE(B2," ",""))+1))*99,99)),A2)),{-1})/(LEN(B2)-LEN(SUBSTITUTE(B2," ",""))+1),0)
Format cell as %age which will indicate %age word match with the other cell. Current formula will tell %age match of col B with col A. You just need to reverse the logic if you want to compare opposite.
